stuck valve...
Old Aug 2, 2009 | 02:09 PM
yoterr's Avatar
stuck valve...
allright i had a thread about 3 weeks ago about having a stuck valve, ive got the head off and the valve spring removed what els is there? the valve seems to be stuck in there, lol i know thats why its sticking, but anyways is there anything els to remove? ive got it all the way down so i cant hit it with the rubber mallot anymore, and ive tried pulling on it but no such luck.. any help would be appreciated
Old Aug 2, 2009 | 02:32 PM
854x4's Avatar
If you have the keepers and valve spring removed then the valve should fall out of the guide but since yours is bent its probably jamed in the guide. You could try working it back and fourth in and out, or use a small punch and drive the valve out. The valve and guide have to be replaced anyway. So you might have to take it to a machine shop.
Old Aug 2, 2009 | 02:48 PM
Plumbrbob's Avatar
maybe try using another vavle stem through the guide, if its bent that bad new guides may be in your future
Old Aug 2, 2009 | 02:57 PM
yoterr's Avatar
yep guide is broken how do i replace that??
Old Aug 2, 2009 | 04:04 PM
myyota's Avatar
You need to take it to a machine shop to have the guides replaced
Old Aug 2, 2009 | 04:47 PM
yoterr's Avatar
i cant do it myself? do i need special tools or somethin? i didint really take everything off like ur supposed to intake carb n all vac lines are still hooked up i just lifted the head up enough for me to work...
Old Aug 2, 2009 | 04:51 PM
854x4's Avatar
Yea, you need special tools to install guides. They have to be reamed to fit the valve and the valve/seat has to be machined for the new valve.
Redeth005
Jun 28, 2018 08:16 PM
rubrsidedwn
Jul 7, 2016 07:28 PM
spiewaker
Dec 16, 2015 01:10 PM
BK2TFUTURE
Oct 11, 2015 08:42 PM
Obmi
Sep 24, 2015 08:10 AM
