Stuck bolts BOLTS! Need advice
Old Mar 23, 2009 | 02:25 PM
cartune777's Avatar
Well I'm stuck, I'm putting installing my lift kit, got every thing off but the lower control arm bolts they are stuck solid I've tried heating them, hammering and cutting them with the sawzall and the blades dull within 15 secs. Of cutting, any ideas?
Old Mar 23, 2009 | 02:31 PM
thook's Avatar
Hehe......yeah, that's hardened steel, bubba. No sawsall will cut through that. You'd need a cut off wheel or a real torch. You may need to get someone with power tools to bust them loose, spray them with penetrant, tighten them up enough to get home where you can finish the job.
On the other hand, soaking with penetrating fluid for a little while......a couple of days.........and using some long cheater bars could do the trick. Just use some 1/2 drive sockets and breaker bar so you don't break your tools.
xzyragon's Avatar
soak em in WD40
Old Mar 23, 2009 | 02:32 PM
thook's Avatar
PB Blaster or Thrust is much better, really.
Old Mar 23, 2009 | 02:33 PM
bigt's Avatar
ahaha wd40
you need THRUST!
Old Mar 23, 2009 | 02:39 PM
thook's Avatar
Yeah, WD40 is not much good for a penetrant, but it works as a good, basic lube......or a torch....hehe.
Old Mar 23, 2009 | 02:41 PM
Ardent's Avatar
Try these blades. They advertise them as PVC blades, but they cut hardened bolts really well. I used them on my rear leaf bolts when I did my lift after I went through 2 10 packs of the Millwake "Rescue" metal blades.
Old Mar 23, 2009 | 02:46 PM
cartune777's Avatar
I'll try the pb blast, I can turn the actual bolt but it's frozen inside the sleeve and the rubber bushing just turns, and your absolutly right about the sawzall blades I have tried every kind/brand there is.
thook's Avatar
Cool. New one on me.
Old Mar 23, 2009 | 02:48 PM
Jay351's Avatar
2ft breaker bar + 2ft cheater pipe... Snap the bolts!
Old Mar 23, 2009 | 02:49 PM
cartune777's Avatar
Except those who makes them
Old Mar 23, 2009 | 02:50 PM
thook's Avatar
Oh, I see. Cut 'em. Or, if you're replacing the bushings anyway, burn them out and then work the sleeve.
Old Mar 23, 2009 | 03:11 PM
cartune777's Avatar
I'll try all of the above I'll keep you posted
Old Mar 29, 2009 | 09:29 AM
cvc9216's Avatar
I'm in the same boat, I haven't gotten around to fixing it yet but does anyone make replacement bushings for the OEM IFS? I can't align my truck because the bolts are siezed in the bushings
Old Mar 29, 2009 | 10:04 AM
Jay351's Avatar
you should be able to get replacments from any autoparts store. Or the dealer..
Old Mar 29, 2009 | 10:10 AM
874runnersr5's Avatar
x2... i wish i had those when i did my rear leafs..
but a cuttoffwheel does wonders man
Old Mar 29, 2009 | 09:02 PM
YoYoMa's Avatar
Give me a lever long enough and I shall move the world.
Archimedes
Old Oct 29, 2012 | 07:47 PM
Run4Mud74's Avatar
Lmao..durn stuck cam bolts!! In the same boat myself. Passenger side rear cam bolt won't budge for nothin'! Tried beatin' it, heatin' it, air hammerin' it, even tried wedging a bottle jack between the crossmember...which my jack didn't like. Latest attempt is with my trusty 'ol cut off wheel. Was going great till my air compressor kicked on and popped the breaker(that I don't have access to)in my little apartment complex garage which left me in the dark. I'm over it. Dealer was the only place I could find new bolts with a very extensive search. $14/bolt..$9/washer. Ordered moog bushings on partsgeek for $86/set. Darn bolt isn't out 'yet' ..but I WILL win ..eventually!=] good luck with yours
Old Oct 29, 2012 | 09:51 PM
Discombobulated's Avatar
I think his bolts would have rusted off by now.
Old Oct 29, 2012 | 10:51 PM
Zpd426's Avatar
These are what I used to cut off my LCA bolts. I had a saws all and about 10 carbide grit blades from harbor freight it took a long time but I got them eventually! WEAR EAR PLUGS! You can find new bolts in the junkyard for really cheap, when I got mine from the junkyard we had some other stuff also. Didnt even get charged for them.
Blazeland does rebuilds.
