Steering Stabilizer?
Old Jun 29, 2008 | 10:24 AM
stupid_mud_gremlins's Avatar
How would you know if a steering stabilizer is shot, I've never had one go on me before and I think that's what it is. When I hit a bump no matter how small, I get yanked off to the side, and I've also noticed some vibration while accelerating. Does this sound familiar to anyone?
Old Jun 29, 2008 | 01:06 PM
anotherjeff's Avatar
Off the vehicle, it's easy to check. Like a regular (not gas-filled) shock absorber, it should have resistance in both directions. A bad one will not have resistance. In fact, that's all it is: A shock absorber!
Old Jun 29, 2008 | 06:06 PM
dutchboy's Avatar
Are the mounting nuts thier? Are they tight? Are the end bushings their and not all rotted out?
Are the stabilizer(s) leaking? Either way. This is a quick and easy job and shouldnt cost all that much.
Old Jun 29, 2008 | 06:47 PM
thook's Avatar
I'd say inspect the whole front end. Even with a bad stabilizer you shouldn't really have any vibrations on acceleration. That sounds more like a steering component.
It's not unusual for an older vehicle to have more than one thing going/gone at the same time particularly if the parts have all been on their for a long time and for relatively the same amount of time. Factory parts, for example.
When I had to replace my idler arm I also found that that two tie rods were shot and the stabilizer, as well. All the original factory parts. So, you may not notice that a number of things are bad until issues compound on one another. I've seen this hanging out and killing time at auto shops, too.
Old Jun 29, 2008 | 06:53 PM
texcat101's Avatar
Ditto, those are characteristics of a more serious problem.
Old Jun 29, 2008 | 07:43 PM
Alright, thanks for the info guys. I guess it's time to start poking my nose into things. I'll post back what I find.
Old Sep 10, 2008 | 09:59 AM
M threezy's Avatar
I am thinking about going the dual stabilizer route since I run 35's on an IFS 4runner. Which ones do you recommend? I'm sure they're all basically the same?
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
live4soccer7
May 11, 2016 06:52 PM
scott90
Oct 4, 2015 09:21 AM
ktm192k
Oct 1, 2015 08:47 AM
