Solid Axle in front
Old Oct 17, 2006 | 10:10 PM
Mister Willie's Avatar
Solid Axle in front
Is it possible to replace the independent suspension in front on my 90 4runner with a solid axle?
Is it recommended? if possible how much does it cost? how long does it take?
Old Oct 17, 2006 | 10:39 PM
Elvota's Avatar
Search under terms like "straight axle swap" or "SAS". You will mind much info.
Cost? Depends, kits start close to $1000 and won't include axle, bigger tires, etc.
Time? A weekend if your a good fabricator and great with a torch and grinder. Probably alllow a week or more if this will be your first major project.
If you are not a qualified welder, my strongest suggestion is to find someone who is and have them attach all the critical parts.
Old Oct 18, 2006 | 04:19 AM
waskillywabbit's Avatar
It can't be done and no one has ever thought of it.
Mister Willie you need to take advantage of the "search" feature at the top of the page here and use It has been done and documented 4.2 bazillion times last time I checked.
If your next question is "how much does it cost?" then you can't afford it.
Old Oct 18, 2006 | 05:07 AM
SteveO's Avatar
The search works really well.........If your really interested, you should search this out and gather as much information, then ask questions to fill the gaps.....
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
gieselman
Oct 12, 2015 01:34 PM
Scotto6591
Sep 1, 2015 03:24 PM
scottyg486
Jul 19, 2015 05:34 PM
