Shroud Help
Old Jun 4, 2012 | 09:54 AM
tresguey's Avatar
Shroud Help
Was having a bit of an overheat issue and just replaced me radiator with a Spectra I purchased through Summit Racing. It is a OE replacement for my 4cyl 4X4. One thing I noticed while swapping them out was to my surprise was my old radiator had a GM logo embossed in the plastic tank. The other was that the new radiator was about 2-3 inches taller. It fit in the mounting points perfectly, but when I was trying to attached the shroud it fell short. The mounting holes fit correct, but the bottom two inches of the radiator was open. I called spectra and they assured me that the 4X4 radiator was slightly taller than the 2wd version. I have searched a bit for a shroud that will be specifically for the 4X4 and have had no luck. Is there a different shroud? Or do they just leave the bottom half open? I seriously doubt that.
Also while overhauling my engine last winter I lost my AC tensioner pulley and hardware. I have also searched for that and have only found the pulley, not the bracket and bolt.
reallynotamechanic
Sep 20, 2015 05:40 PM
upongame619
Aug 1, 2015 12:12 AM
TURBOrunnerNM
Jul 20, 2015 08:31 AM
Edionne13
Jul 9, 2015 01:59 PM
zd92655
Jul 5, 2015 04:25 PM
