Resetting the steering stop bolts or procedure on adjusting (4" lifted IFS)
Old Mar 8, 2018 | 10:09 AM
211's Avatar
211
5 Year Member
Purchased a new set of delrin caps for the stop bolts and noticed one of the bolts is broken.
To replace it I'll probably just buy all 4 but I'm wondering is there a procedure to reset or adjust the position of these bolts? Not sure if it matters but this is a '92 pickup (IFS) with a 4" suspension lift. Does the turning radius need to be increased buy the stops due to the increased angle of the axles or anything like that?
The truck already has a really wide radius and I'm wondering if the PO did it intentionally. If I can reset the stoppers so they're in further (tighter radius) I'd like to. Just not sure if there's any issues with having them too far in.
Old Mar 8, 2018 | 10:59 AM
Kolton5543's Avatar
Essentially their biggest reason for being used is to stop CV bind. If they are set in too far and the CV will bind up and then promptly grenade. I don't think there's any real special procedure to do so. Just turn the wheel without the stops and see where the CV starts to bind up. Install the stops a littler further out than that point.
Old Mar 8, 2018 | 01:38 PM
211's Avatar
211
5 Year Member
Whats the proper way to do that?
Jack up the truck or do it in the parking lot?
babyfood1217
Jan 9, 2012 06:49 PM
crackerjack
Jan 16, 2007 01:15 PM
apc
Aug 7, 2006 01:30 AM
silverunner99
Jan 12, 2004 06:29 PM
4Runner2003
Nov 3, 2003 08:54 PM
