Rear Rims are very hot.
Took the 86 pickup out on the highway today, and seem like it was being held back by something. Check the rear wheels and they are very hot, basically burnt my finger on the rear drums. Is this normal? Do these rims run that hot. I just had my rear brake cylinders changed, and am wondering if he didn't make the right adjustments to the rear brakes. He said everything look good and there shouldn't be any problems. He suggested to loosen off the emergency brake cable as well, but I don't think that is the problem.
If I have the truck up on jack stands, (no posi) and I turn the rear wheels by hand, how much resistance should i feel. and should the wheel continue to spin when i let go?
I know these are basic questions, but .....
i do not know all too much about brakes besides that they can be a royal pain. Jack up the rear end take off the wheels and drums and take a look, maybe your shoes have swollen due to brake fluid contamination, maybe your drums are scoured, or (what i think the issue is) adjust parking brake... there should be a geared adjuster that u turn with a couple of pair of flat head screwdrivers, trial and error should determine what direction "loosens or tightens" them... A quick search on Yotatech should bring up some results for ya on how too adjust them.
the brakes are designed to drag slightly in case the get wet. that way they will dry themselves as you drive. but they shouldn't get as hot as you are describing. warm, a bit uncomfortable to the touch is ok, but certainly nothing that you can't touch.
this heat gets transferred to the wheel directly from the drum.
when I turn my wheels they will spin a bit after I let go if I give them a spin.
Does anybody know how hot the rear diff is supposed to get,like when you get off the hyway,I just installed a 4.88 third and took a test ride,checked for leaks and it is hot enough that you can't leave your hand on there too long,the 5sp tranny is about the same
If you jack up the rear axle then try to turn a wheel by hand, it should spin maybe 1 turn before coming to a stop. The point being that it should turn without much effort- you should feel some drag but shouldn't feel like you're fighting to turn it. One hand laid flat on the tread trying to turn it should be enough to move it.
check your brake adjustment
should spin with out much drag from the brakes
if the brake adjustment is good then check your diff fluid level, if it is good then i'd say you got a wheel bearing going, are both wheels the same temp?
Years ago a dragging brake shoe on my folks' '72 Gran Torino caused the wheel to get so hot that the tire blew at 55 mph on Interstate 80. We were lucky there was nobody cruising next to us because we were all over the both lanes of the highway and narrowly avoided flying into a ditch. My dad put me in charge of removing the wheel and I burnt my fingertips on the lug nuts. We put on a spare and tried to go, but the brake had seized ... we were stuck.
My advise is, I would avoid driving your truck until you can get to the bottom of the problem, for your own safety and the safety of others.
Jun 1, 2021 01:51 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
