radiator leak/high idle and surge
I don't think so, but not an expert.
My 94 22RE surges when the outside temperature is below around 40 F. In my case, the problem is the auxiliary air valve. The passages where coolant is supposed to flow is completely packed with crud... a product of me not flushing the cooling system for years at a time.
Aux air valve:
Aux air valve:
yes, A radiator can and will relate directly to a high idle and surge. The auxiliary air valve posted above is directly affected if it gets no coolant or air bubbles. Fix the leak, refill the system and purge it of any air bubbles.
Road Bull
Oct 10, 2015 04:55 PM
