Plugs
Old Jan 16, 2016 | 04:22 PM
elcaminokid69's Avatar
Plugs
Need help. Was replacing plugs on my 92 3.0 all went well till I got to passenger side rear plug. I can not for the life of me get the angle right. Any suggestions or advice appreciated
Old Jan 17, 2016 | 05:38 AM
MudHippy's Avatar
That's the one you need x-ray vision for.
The only advice I have is use a small piece of hose as an extension.
Once you do it a dozen times or so, it gets a little easier. Not much though.
Old Jan 17, 2016 | 05:43 AM
There is a sort of filter on the firewall above the wheel well I was thinking of removing to get the angle
Old Jan 17, 2016 | 05:47 AM
MudHippy's Avatar
That might work.
Old Jan 17, 2016 | 05:52 AM
Too many hoses in the way. The only thing I can think of is that filter thing.
Old Jan 17, 2016 | 04:45 PM
RJR's Avatar
RJR
Are you having difficulty getting the socket on to remove the old one, or having difficulty getting the new one started in the threads. If it's the first, a wobble extension or a u-joint in your socket extension will help. If it's the 2nd, MudHippy's advice to put a short piece of vacuum tubing (actually, I think I used a piece of fuel line hose) on the plug and use that to get it started might be helpful. Kind of works like a flexible coupling.
Yotta88
Nov 9, 2015 11:10 PM
Runnin13s
Nov 5, 2015 07:45 PM
Edionne13
Nov 4, 2015 05:20 PM
Chick-N-Picker
Oct 29, 2015 04:19 PM
nekchris
Oct 27, 2015 12:22 PM
