Overheating Problem!
Old Aug 19, 2010 | 01:17 PM
rockingthe2's Avatar
Exclamation Overheating Problem!
My 95' toyota 4runner's engine is overheating so badly that it is causing the antifreeze to boil, and steam out the overflow tank. It has a rebuilt engine and a loose vacuum hose do you know what the problem could be??? It has a V6 enigne with 4wd
Old Aug 19, 2010 | 01:54 PM
pruney81's Avatar
Maybe fan clutch, radiator water pump or head gasket. I wouldn't let the 3VZE overheat fro too long because if it isn't the head gasket it will be eventually.
Old Aug 19, 2010 | 02:56 PM
swampfox's Avatar
thermostat maybe.
Old Aug 19, 2010 | 10:56 PM
pruney81's Avatar
good call, I forgot about the thermostat.
Old Aug 19, 2010 | 11:00 PM
jpsstewart3's Avatar
Does the idle change at all before/while overheating?
Old Aug 19, 2010 | 11:13 PM
Jory121's Avatar
samething happened to me, and yes it was my headgasket
Old Aug 19, 2010 | 11:42 PM
wyoming9's Avatar
Red face
First thing do a pressure test on the cooling system!!!
I have seen radiator cores blocked cause this problem.
Also air pockets in the cooling system can do this also.
Pressure test go from there.
the1998sr5
15
Jul 14, 2020 08:35 PM
the1998sr5
27
Nov 17, 2015 09:30 AM
Logz808
Jul 26, 2015 07:09 AM
the1998sr5
Jul 16, 2015 06:20 AM
Avenged
Jul 9, 2015 07:55 AM
