No idle
Old Jan 1, 2009 | 06:28 PM
Focspeed's Avatar
No idle
Have a 95 4 runner and to stay idle you have to keep your foot on the gas.What could be the problem.
Thanks
Old Jan 1, 2009 | 06:31 PM
91Toyota's Avatar
Idle could be set too low. Clogged air filter?
It would also help to include engine and trans too
Old Jan 1, 2009 | 06:32 PM
toyota4x4907's Avatar
Pull codes and see if anything comes up.
What engine?
The Idle Air Control valve may be malfunctioning.
Also, does it outright die? or does it just idle really bad, really low rpm?
Old Jan 1, 2009 | 07:43 PM
abecedarian's Avatar
brake servo vacuum line may be leaking
duct from the throttle body to the air flow meter may be leaking
duct from the PAIR resonator to the air flow meter may be leaking
Throttle position sensor or air flow meter may be malfunctioning
ignition advance (timing) may be set incorrectly
catalytic converter may be partially plugged
many things can cause this issue
Old Jan 2, 2009 | 09:59 AM
Focspeed's Avatar
the engine is v6 and is a automatic. vechile is not mine is grandmothers i am going to check all these things
Blamalam
Mar 12, 2022 07:34 AM
Marsheen
Feb 17, 2016 12:29 PM
GrimWolf
Aug 28, 2015 03:36 AM
noosh
Aug 21, 2015 03:49 AM
Sarcazmo
Aug 15, 2015 08:22 PM
