Newbie post, 89 4-runner, where is the fuel filter??
Old Nov 10, 2010 | 01:02 PM
brewmiss96's Avatar
Heh, yeah. So my 89 4-runner has a rough/loping idle and has been stalling at stops. I adjusted the plug gap and it helped a little, also replaced the wires again (replaced them in Feb) and I'd like to replace the fuel filter after reading on here about how it helps with high mileage vehicles. But I have failed to locate it in the engine compartment, and after tracing the fuel lines I wondering if it is, in fact, on top of the fuel tank like Haynes says it could be.
My 89 4-runner is a 4 cylinder, EFI, with about 400k miles. And I'm about 90% positive the fuel filter hasn't been changed, ever. So, is it in the engine compartment and I missed seeing it, or is it on top of the tank and I need to drop the tank to replace it?
I would also like to know of any good threads for this model because I'm getting to the point where I want to redo some things, like the interior and paint. The engine is pretty sound, I do most of the maintenance myself, and major services like timing chain, new head gasket, new starter, have been done within the last 3 years.
Thanks!
Old Nov 10, 2010 | 01:09 PM
Outsane's Avatar
there are two I believe..
One is under the intake manifold, pain in the ass to get to
Factory Service Manual
http://www.ncttora.com/fsm/
Old Nov 10, 2010 | 05:17 PM
brewmiss96's Avatar
There is one inside the fuel tank on the fuel pump, it is the other one I want to change. I will have to wait for light tomorrow and take the brush guard off to see if I can find the sucker since it wasn't topside. Thank you for the manual link, I found a diagram that helped.
Old Nov 11, 2010 | 12:05 PM
brewmiss96's Avatar
Eureka! Thought I had seen that sucker somewhere, probably when I changed the starter. Thank you! Now just have to find my jack stands....
Old Nov 15, 2010 | 08:44 AM
tumor21's Avatar
It is a PITA to get to that filter. I did mine when I did my headgasket just because I figured I had no better opportunity with the head and intake manifold out of the truck. In hindsight I should have relocated it somewhere else in the engine bay for easy access. Here is a pic from pirate4x4 of the filter location on a stock 22re...(The starter is directly below it)
If you're thinking of relocating it when you change it, there's a good thread here on YT...
https://www.yotatech.com/forums/f116...cation-195162/
...Hope this helps.
Old Nov 15, 2010 | 08:58 AM
scuba's Avatar
There is no actual fuel filter in the tank.
What you guys are referring to is the fuel pump pickup screen.
It may technically be a filter but, it is not referred to as a fuel filter.
And the screens in the tank normally don't require changing.
smthwsn357
May 1, 2024 07:28 AM
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
nick b
Jul 11, 2015 04:38 AM
