Need Help getting lower ball joint back in ASAP!!!
Old Jun 25, 2011 | 03:47 PM
foskco87's Avatar
So I have gotten my old ball joint out. I have the new one bolted to the steering knuckle. Now this is where everyone says you are home free but I cant get my hub to move back into place so that the bolt sits over the hole. The hub is angled outwards and No matter how much I push on it it wont move. I dont know what to do as it is pretty apparent that it has to move if the ball joint will ever sit into the lower A arm. I am wondering if maybe when I jacked the hub up if I pulled the CV differential apart and now its stuck? Can this even happen? I really need help. Everyone says its so easy but I just cant get it back into place. What am I doing differently?
Old Jun 26, 2011 | 08:21 AM
Challenga's Avatar
Rotate your CV joint and it should push back so that your ball joint will line up. I happened to me when I just rebuilt my front end. I had to pull a little on the cv, rotate it a little, then push it back in. I should go right in. Otherwise I would suggest loosening up your torsion bar so that you can move your upper control arm up and down then doing the same thing again. I will go in there. Unless something is major wrong.....which I doubt.
Good luck man.
Old Jun 26, 2011 | 10:08 PM
foskco87's Avatar
Thanks dude. Thats exactly what it was. I thought that would be the problem and with a few spins it went back in. Wouldn't have made a thread if I knew it would be such an easy fix hah. Thanks again though.
lledwod
Aug 30, 2016 01:03 PM
icentropy
Jul 11, 2015 07:21 AM
coryc85
Jul 7, 2015 04:05 AM
ptb12
Jul 5, 2015 01:49 PM
elwood73
Jul 5, 2015 07:07 AM
