is it my head gasket or intake gasket
Old Mar 15, 2010 | 05:48 PM
94playtoy v6's Avatar
my dad says its the intake gasket because the idle is crappy when u first start it and its burning coolant i put a new t stat in it any help would be great o and where should i buy these gaskets at carquest it is 180 for a topend gasket kit
Old Mar 15, 2010 | 05:58 PM
881stGenRunner's Avatar
dude, not sure what to tell you with that little info. check out www.engnbldr.com quite a bit cheaper and much better parts
Old Mar 15, 2010 | 06:37 PM
well when u first start it it idles like it is very choppy but low idle and are theese good gaskets some said toyota gaskets are the best and the ones atparts stores are junk
Old Mar 15, 2010 | 11:29 PM
abecedarian's Avatar
I'm guessing that it idles fine with a warm start?
If so, an intake gasket will not fix a problem with the auxilary air valve.
And then you can figure out where the coolant is going.
kgcwb44
Jan 29, 2023 10:02 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
toofly1999
Jul 25, 2015 07:09 PM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
