Misfire
Old Feb 22, 2026 | 10:30 AM
desmondpetersen's Avatar
Misfire
Just picked up a 95 3vze with 215000
had been siting for a couple years, when we went to start it we hooked the battery up reverse polarity. Once replacing the fuses that popped, it drives but misfires on cylinder 3 and has a engine code 25(lean air)
Replaced the spark plug n wire, didnt fix it.
Im new to this engine, so any advise helps.
Havent done a compression test yet, i was gonna try the injector next, but was wondering if the reverse polarity battery might have blown any electrical things i should check
Ive heard about valve tunes, they sound a little complex for my skill level, when should i think about getting that done? When i can hear them slapping?
If i run a compression test and find low compression, its likely a valve, in which case i would have to open the valve covers and adjust it anyway, right? How hard would it be to just do the rest of them?
Last edited by desmondpetersen; Feb 22, 2026 at 10:33 AM. Reason: Wrong image uploaded
BlackNite3
Nov 3, 2011 12:25 AM
Green93
Dec 18, 2008 08:54 PM
YotaJunky
Mar 3, 2008 08:49 PM
Jen97
Mar 25, 2007 07:20 PM
iggy
Sep 27, 2005 12:13 PM
