Manual transmissions: 4-speed vs 5-speed
How do the final drive ratios of the G57 5-speed and G40 4-speed compare? I'm having trouble finding reliable info on this.
If a 5-speed can be sourced cheap, is it worth the trouble of swapping it into a pickup originally equipped with the G40? Are the physical dimensions of each transmission the same? Mounting points, etc? Would swapping trannies also require different brackets, driveshaft, etc?
FS[FourCorners]: First Gen Tacoma/4Runner Manual Hub Spindles
G-off
Dec 29, 2015 12:44 PM
mordell
Sep 12, 2015 10:13 AM
zz_denis
Sep 6, 2015 03:43 PM
kelly1450
Sep 2, 2015 12:29 PM
