Lower control arm bushing
Old Jul 20, 2015 | 06:46 PM
andrewtexas123's Avatar
Hey guys my 88 Toyota pickup 2wd has a squeakkkkky front suspension so I tore into it and got a bushing kit from Energy Suspension. Every thing looks great but my LCA bushing seems like its a super loose there's side to side and forward play.
When I pushed out the old bushings i don't recall any outer sleeve or anything that would make it a tighter fit. Did I miss something on the install? Is there an outer sleeve?
https://www.youtube.com/watch?v=dzl_...ature=youtu.be
Thanks, Andrew
Old Jul 21, 2015 | 04:57 AM
Turd Furgeson's Avatar
The old bushing could have worn out the hole in the control arm. That happened on my old camaro,had to find another control arm.
Old Jul 22, 2015 | 09:40 AM
I still had to press out the old bushing so its not like it wore out the control arm enough to have this much play. Any one know for sure if there is an outer sleeve or not? I called energy suspention about it and they said there is and i think there isnt..
Old Jul 23, 2015 | 11:22 AM
GDR's Avatar
GDR
The stock bushings are bonded rubber to inner and outer sleeves. Maybe you are supposed to reuse the outer sleeve?
How do the uppers fit?
88sasturbotoy
Jan 30, 2026 01:57 PM
bobjohnson2121
Aug 18, 2015 06:17 PM
mavenator
Aug 13, 2015 01:12 AM
kirkrunner
Jul 27, 2015 07:59 PM
1994toyota
Jul 17, 2015 03:03 AM
