location of diag. port?
Subscribe
Oct 31, 2009 | 06:58 PM
So started up my new motor today and learned I have a lot left to do. It's a1986 22re manual 4x4. I have a few coolant leaks and the thing runs like crap. It misses a lotand if I let off the gas it lopes down until it eventually dies. I have a check engine light as well. The manual said my Te1 and e1 terminals were over on the drivers side by the ignitor but, for the life of me I can find it anyhwere. Ive been slwoly learning the guy who owned this truck before me knew how to screw things up. Does anyone have an idea of where else it could be or if it is gone what else I can do to pull the codes. I'm fariliar with the old paper clip scan tool trick but I think my diagnostic port has been removed. If any of you guys have anby other advice as far initial tuning goes I'm all ears. This week I plan on fixing the vacumm leaks, setting the timing, fixing the coolant leaks, and somehow pulling the codes.
Any help is GREATLY appreciated.
Thanks,
Andrew
Reply 0
Oct 31, 2009 | 07:09 PM
From
http://www.4crawler.com/4x4/CheapTri...CheckConnector
(circled in light blue):
Reply 0
Oct 31, 2009 | 07:12 PM
Have to add, since I noticed the pic I posted and the one yota4runna posted have the plug in different places, both show the plug with only 2 wires is the check connector.
Reply 0
Oct 31, 2009 | 07:15 PM
Thanks guys. Now that you have posted it remeber sseing that on the 4crawler site. So essentially I just jumper the two coonectors on the light blue plug right?
Reply 0
Oct 31, 2009 | 07:16 PM
yep, then turn the key to 'on' and count flashes.
Reply 0
Ok I was wondering why they were different in each picture.
Reply 0
Oct 31, 2009 | 07:19 PM
right o. Got any other advice as far as things to check for with the given symptoms outside the usual? Come on I know you do abe.
Reply 0
Oct 31, 2009 | 07:26 PM
Pull the codes first and we'll start there.
Beyond that, a comprehensive list of performance issues would help. Things like how does it run when cold... when hot... idle speeds cold and hot, etc.
Reply 0
