Lift and driveline questions
Old Apr 12, 2008 | 09:29 PM
stupid_mud_gremlins's Avatar
ok, I did a quick search on this and there is a LOT of info on lifts and problems with the drive line. What I'm wondering is how much higher than stock have people gone without having to change their drive line. Would I be better off to build a 2 piece (3 U-joint) shaft, or lower the transfer case. I'm just kind of wondering how much Trouble I'm going to get into once I get everything in. I've been working on this suspension project for over a month and a half now and it's almost ready for finishing. The last thing I want to do is get it finished and find out I can't move the truck without binding a U-Joint.
Old Apr 12, 2008 | 09:34 PM
tc's Avatar
tc
Ummm - how much lift are you looking to do here? And what kind?
If you rotate your pinion to have a good angle, you can do A LOT of lift before binding...
Oh - and a 1pc driveshaft is better for lift than a 2 pc...
Old Apr 12, 2008 | 09:38 PM
muddpigg's Avatar
I measured the angle of the drive line, I believe should be less than 11*. Check the flanges as they should be parallel. Ask how I know
Check Roger Brown's site http://www.4crawler.com/4Runner.shtml awesome info here.
Old Apr 13, 2008 | 04:07 AM
ovrrdrive's Avatar
Mine is up 7" right now in the back and I don't have any driveline problems at all. And I still have the 2 piece driveshaft in.
Old Apr 14, 2008 | 03:52 PM
elripster's Avatar
This is a very hard question to answer. Wear on the transmission flange an drear diff pinion bearings will affect this. For example, I just regeared and once again solved a driveling vibe issue that I had from stock to 2" of lift.
The flange angles do need to be equal and this can be very hard to accomnplish. On a side note, if you run a CV or double cardigan, you can rotate the diff to point at the t-case which increases drive shaft clearance. On a leaf sprung truck, you can have the angles equal at rest but the change in angle that takes place when you accelerate or decelerate can induce vibrations.
Those that are running more that 4-5" of lift without vibes on stock drivelines likely have tight bearings and good equal flange angles. If you have a stock diff at this point, good luck with the vibes but a $500 driveshaft couldn't fix what the new bearings during a regear did on my '89 4runner.
Frank
Old Apr 14, 2008 | 06:16 PM
longhungsilver's Avatar
very informative
Frank
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
coffey50
Jul 28, 2015 10:55 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
