kinda high idle than normal
Old Oct 6, 2010 | 09:57 AM
70elcoss's Avatar
about a month ago i changed my spark plugs and installed a K&N FIPK. i did the plugs at the same time while i had all the airbox crap out of the way. i used the NGK v-power plugs and couldnt find my plug gap tool so i used one i had laying around
looks like this:
http://cdn.oneprojectcloser.com/wp-c...g-gap-tool.jpg
usually i use the fully round ones like this one but couldn't find it
http://users.ntplx.net/~ullman/images/8e.jpg
so i gaped them to .032 i think as best i could and put them on.
when driving around after warmed up my idle is pretty consistent around 1k or slightly higher. sometimes it drops to the 800-900s where it was before.
so basically should i go back and regap with a better gapper? would bad plug gaps cause the slightly higher idle?
oh and i dont remember if i gapped them to .032 or .036, its for a stock 3vze
Old Oct 6, 2010 | 10:12 AM
kzink's Avatar
I have the same idle after I did plugs and wires but I did stock gap I forget what it was but I looked it up when I did it and I have a high idle too right around 1k
Old Oct 6, 2010 | 10:49 AM
93yotaSR5's Avatar
mine idles around 1000 and i use the ngk plugs at the same gap
Old Oct 6, 2010 | 11:46 AM
xxxtreme22r's Avatar
idle speed is not determined by plug gap, it is determined by the idle screw position. If the idle was low at one point because of worn out plugs (which does happen) and then the idle screw was adjusted to bring the engine idle back up to spec 700-750 I believe and then new plugs were installed the idle would go up as you guys are describing.
1000RPM is too high on the RE's IMO and can lead to other problems like engine run quality when applying brakes etc etc. Not to mention poor gas mileage.
Other things that affect idle speed are air/fuel mixture and timing.
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
ty1er
Jul 19, 2015 06:42 PM
kyletbert
Jul 17, 2015 11:39 AM
