I'm buying a 1995 ext. cab Toyota pickup.
Old May 6, 2008 | 05:03 PM
HAVOC's Avatar
I'll post pics this weekend. It has a bad rod knock and it needs some body work. Owner wants $500 for it. I'm using it to replace my 1989 reg. cab pickup which has a hole in the frame and the body is shot.
Is there anything I should look out for while I have the engine out? I will be replacing the clutch.
Old May 6, 2008 | 05:39 PM
Alex 400's Avatar
what engine is it? how are the CV's?
Old May 6, 2008 | 06:09 PM
HAVOC's Avatar
3.0 V6, left C/V has a small tear in it.
Old May 6, 2008 | 09:00 PM
Alex 400's Avatar
yeah that C/V should be taken care of before too long. so are you just going to rebuild the 3.0 or have you considered a 3.4 swap? if i had a blown motor and had to completly rebuild it, i would seriously be considering putting in a 3.4.
Old May 7, 2008 | 02:36 AM
HAVOC's Avatar
I'd love to do a 3.4 swap,(moneys a little tight). A guy that I work with has a 3.0 shortblock that needs rod/main bearings and rings. I'll use that if the crank is shot on the truck I bought. I'm getting the shortblock for free. I just have to buy the parts.
The heads were done (supposedly) at the dealer about 5,000 miles ago. So when I pull the engine I'll see where I need to go from there.
Aleeex_u
Jun 5, 2016 06:52 PM
Gamble_STi
Jun 27, 2015 07:54 PM
GorgeRunner
Jun 27, 2015 07:01 AM
dirtrider0129
10
Jun 24, 2015 12:24 PM
94more
Jun 19, 2015 01:55 PM
