Idle surge when lights/brake lights are on
Old Jul 19, 2009 | 05:20 AM
dthurst's Avatar
Hi. I am new to the forum and have searched for this problem, but haven't found an answer directly relating to the problem I am having. I apologize in advance if it was on the home page.
I recently traded for an '89 Toyota V6 5 spd 4x4 that supposedly has a '95 model engine in it. I can tell the motor has been changed, but I can't verify the year.
I have an idle surge when the truck is warm and the lights are on, or if the brakes are applied. It also seems to idle too high when it is warmed up. Here is what I have tried so far....
I first thought brake booster, so I plugged the vacuum hose from the intake to the brake booster. It still surged when the brakes were applied. I tried this before I realized that I have the same problem when the lights are on without hitting the brakes.
Secondly, I figured that since the truck has a steel flat bed and trailer lights in place of real rear lights, that it could be a ground problem drawing power from the fuel pump. I grounded the fuel pump and same problem...
I am stumped. Could anyone please offer some advice on this issue? I appreciate the help!
Old Jul 26, 2009 | 04:57 AM
dthurst's Avatar
UPDATE: I adjusted the idle down and it has solved my problem!
smthwsn357
May 1, 2024 07:28 AM
Charecter1
Nov 6, 2023 10:08 AM
Sleaker
Aug 26, 2020 06:03 AM
ddg71
Jul 24, 2015 01:24 PM
jake_v
Jul 22, 2015 03:17 PM
