Hypoid tranny/xfr case oil, or no?
I'm getting ready to change out all the fluids in my truck. I have a V6, manual tranny, VF1A xfr case, 4wd... Here's how the service manual reads for my truck's specs...
FLUID CAPACITIES TABLE
Application (1) Quantity
Crankcase (Includes Filter) ........................ 4.8 Qts. (4.5L)
Cooling System (Includes Heater)
A/T ............................................. 10.4 Qts. (9.8L)
M/T ............................................ 10.6 Qts. (10.0L)
Manual Trans. (SAE 75W-90/API GL-5) ................ 3.2 Qts. (3.0L)
Automatic Transmission (Dexron-II)
2WD
Dry Refill ..................................... 7.6 Qts. (7.2L)
Drain & Refill ................................. 1.7 Qts. (1.6L)
4WD
Dry Refill ................................... 10.9 Qts. (10.3L)
Drain & Refill ................................. 4.8 Qts. (4.5L)
Differential
2WD (SAE 80W-90/API GL-5) ........................ 1.9 Qts. (1.8L)
4WD
Front Axle
With ADD (2) (SAE 75W-90/API GL-5) ........... 2.0 Qts. (1.9L)
Without ADD (2) (SAE 80W-90/API GL-5) ........ 1.7 Qts. (1.6L)
Rear (SAE 80W-90/API GL-5) ..................... 2.3 Qts. (2.2L)
Transfer Case
A/T (Dexron-II) .......................... .8 Qt. (0.7L)
M/T (SAE 75W-90/API GL-5) .............. 1.2 Qts. (1.1L)
(1) - Approximate quantity listed.
(2) - Automatic Disconnecting Differential (ADD).
If you look at it... the tranny and transfer case say to use 75W-90... Does that mean, I could just use standard 75W-90 and not have to use Hypoid (or GL-5)? Thanks!
2WD
4WD
Differential
4WD
Front Axle
Transfer Case
WTB[PacNorWest]: w56 c manual trans with t-case and drivelin
89hilux1
Jul 19, 2015 01:32 AM
crashburnoveride
Jul 10, 2015 06:39 AM
toyoda8488
Jul 5, 2015 10:18 PM
