How do you test the knock sensor?
Old May 17, 2006 | 12:09 PM
bsanders30096's Avatar
Question How do you test the knock sensor?
1995 SR5 4Runner 185k miles... I'm redoing the top end, and have read that it's good to replace the knock sensor wire. OK, that's fine...only $13 or so. Is it really worth while to change the knock sensor too at $150? That's just crazy! Is there a way to test it? How long do these things normally last? Thanks, Brian
Old May 17, 2006 | 12:16 PM
snap-on's Avatar
its a simple ohm test from what i remember.
dont have the specs but you could find them in the online FSM
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Old May 17, 2006 | 12:58 PM
eric-the-red's Avatar
According to my manual there should be infinite resistance between the sensor terminal and housing, if not it should be replaced.
Old May 17, 2006 | 01:12 PM
Question
Has anyone ever had a knock sensor go out on them???
Old May 17, 2006 | 01:49 PM
midiwall's Avatar
Yeup... two of them, within a month of one-another.
Big babble over here: https://www.yotatech.com/forums/f2/cel-code-p0330-saga-56080/
In that reading, note how I ended up dealing with the 2nd sensor...
I wired them together.
Not really recommended, but I've been running like that for a LONG time, and it's "fine".
tobylab
Dec 3, 2015 08:41 PM
raptor510
Aug 19, 2015 02:15 PM
Flossy
Aug 5, 2015 05:14 PM
nonstop
Jul 24, 2015 06:29 PM
