How do I change coolant temp sensor on 3.0
Old May 28, 2011 | 10:21 AM
markfagus's Avatar
Guys, I pulled my CEL codes and have a 22, which is the coolant temp sensor. I am headed to Auto Zone to pick up a replacement but looking at the motor it seems kinda tough to get to.
Any suggestions? After I pull the plug off the top can I get a socket with an extension on it? Getting a wrench down on it seems like a nightmare.
thanks for the info.
Mark
Old May 28, 2011 | 10:42 AM
bugs1961's Avatar
You should be able to get a deep socket on the sensor but you may need a u-joint adapter between the socket and extension to make the angles work. They make things so much easier when space is tight like at the back of the 3.0.
Old May 28, 2011 | 11:14 AM
sb5walker's Avatar
If the socket won't fit around the plastic connector, try an open end crows foot:
http://www.amazon.com/TEKTON-2580-8-...dp/B000NPR2BC/
Old May 28, 2011 | 12:34 PM
bugs1961's Avatar
Good point. I bought a set of those from Sears (Craftsman) years ago--don't know if they still have them, but worth a look.
Old May 28, 2011 | 08:34 PM
markfagus's Avatar
guys, thanks for the info. I used a 19mm deep well socket and a 9" extension and it worked fine.
Mark
Poncho0206
Jul 10, 2015 06:21 PM
Avenged
Jul 9, 2015 07:55 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
bryan34w
Jul 6, 2015 05:53 PM
wilbertd
Jul 6, 2015 07:39 AM
