How can I test my injector connectors
Old Jan 25, 2007 | 05:48 PM
Lifelongtoy's Avatar
Question How can I test my injector connectors
How can I test my fuel injector connectors to see if they are working right? I suspect some wires may be faulty. Im trying to diagnose a dead cylinder.
Old Jan 25, 2007 | 07:07 PM
dcg9381's Avatar
The best way to do it would be to have an oscilloscope.
The 2nd best way to do it would be to put a test light across the terminals of each injector and see if you can see it flashing when the truck is running.. It's likely that it'll flash so fast that it looks like it's lit all the time. LED test light would be better.
Nice dog, btw.
Old Jan 25, 2007 | 07:18 PM
I have a pretty good multi-meter, is there any way I could use that?
I have the throttle body off right now but plan on putting it all back together tomorrow, Can I perform any test (maybe on the connectors) while the engine is off?
Thanks, btw.
Old Jan 25, 2007 | 07:24 PM
dcg9381's Avatar
With the iginition on (engine not running) you should have 12v at both prongs of the connector when testing between the prong and engine ground.
That tests the 12v side.
The ground side has to be tested as I've suggested with the engine running - or at least turning over, across the connectors - one side of the volt meter on each prong of a single connector.
Old Jan 25, 2007 | 07:51 PM
tomorrow mourning, thanks.
Blamalam
Mar 12, 2022 07:34 AM
Sleaker
Aug 26, 2020 06:03 AM
TACOJO
Nov 27, 2015 05:26 PM
steve miller
Oct 10, 2015 01:40 AM
raptor510
Aug 19, 2015 02:15 PM
