Front differential help
hi all,.. i got a 94 4runner 4wd.. my problem is a leak on the passenger side where the half shaft connects to the front differential. i took off the cv axle and inspected the area of the differential and found a great amount of grease building up, also there is a lot of play compared to the driver side. is this an easy DIY fix? im assuming that the seal on that side needs to be replaced. being that there is a significant amount of play when i grab the center of the cv axle and give it a shake,.. im wondering if theres a bearing on the inside of the differential that has gone bad. do i have to remove the diff. to replace the seal? i'd appreciate any help. thanks
I almost forgot I had this link on my site...
http://gearinstalls.com/needlebearing.htm
Diff must come out. I have the same issue, started a thread about it last week.
https://www.yotatech.com/forums/f116...issues-238690/
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
ripp96
Jul 25, 2015 02:32 PM
scottyg486
Jul 19, 2015 05:34 PM
WTB[PacSoWest]: Looking for a electric locking differential motor/ actuator
AaronM
Jul 8, 2015 07:15 PM
