Freewheeling hub: axle only unlocks if turned backwards
Old Oct 6, 2021 | 11:37 AM
Paul22RE's Avatar
5 Year Member
I just completed replacing front bearings and my left hub came apart when it was out. Put it all back together & works fine but the left axle will not unlock unless I turn the wheel backwards (even slightly). Right side axle unlocks without having to turn it backwards. I did put the hub back together correctly (I think?) and rotates smoothly when turning between free & lock. Is this normal if that axle is the one the diff is trying to turn? Or did I do something wrong reassembling the hub springs/collar/clutch? Thanks
Old Oct 6, 2021 | 04:15 PM
wallytoo's Avatar
something is incorrect. the wheels don’t need to rotate to engage or disengage the hubs.
Bajallama
Jan 4, 2013 08:10 PM
Witchgrass
13
Dec 30, 2011 09:50 PM
88Cleve4runner
Jan 20, 2009 04:47 PM
ToyYoda
Mar 25, 2007 07:12 PM
