Found plastic pieces in my oil pan? How do my valves look?
Old Jun 24, 2018 | 08:29 AM
Jakez's Avatar
Found plastic chunks in the bottom of my oil pan, so I figured that clanking sound was my timing chain guides missing and not just noisy valves... so I bought 2 new guides but when I took the valve cover off and it looks like I do have guides?? Is it possible that only part of the guide(s) broke off?
Old Jun 24, 2018 | 11:04 AM
Pat4wd's Avatar
From above you are only seeing a little bit of the guides so you could still have broken guides. It also looks like the passenger side guide might be broken on the upper side. Also if there had ever been a timing chain job done in the past a lot of times folks do drop the pan and fish out the pieces.
Old Jun 27, 2018 | 12:01 PM
DeathCougar's Avatar
Part of your guide has broken off. You need to replace your guides.
ehertz
Jun 30, 2010 03:55 PM
Schroby
Sep 29, 2009 04:50 AM
4ever4running
Aug 31, 2009 05:10 PM
surfh2o
10
May 11, 2009 09:18 AM
mrtejman
Sep 26, 2007 05:44 AM
