Fluids
Old Mar 18, 2013 | 04:50 PM
95 4runnerv6's Avatar
Fluids
I have a 95 4runner 3.0. Does anyone suggest certain transmission rear and front diff fluids. Also transfer case. And how much. I appreciate all the help I receive on here.
Old Mar 18, 2013 | 05:08 PM
AZ94RUNNER's Avatar
Red line mt-90 for the tranny if it is a 5 speed. I use 85w 140 in both front and rear diffs here in AZ. 100 degree summers -5 degree winters.
Old Mar 19, 2013 | 06:06 PM
Jake_D's Avatar
Mobil1 is what i use, i think the ft and rear take a little over 2qt each. if you have a auto use dex 3 in the trans and transfer. i think the trans takes 4ish qt when you just drop the pan and the transfer case takes 4 or 5. do a search and you will find the exact numbers
Old Mar 24, 2013 | 08:47 AM
daved5150's Avatar
Do yourself a favor and use the search function as you will find a ton of threads addressing that same issue. There are also links in threads to online factory manuals here also. Check out this thread here where I posted about which gear lube to use in the tranny etc...
ladybugRC
458
Aug 21, 2020 10:41 AM
zanzabar0
Oct 11, 2015 02:56 AM
bradahman
Oct 1, 2015 09:24 AM
gentry
Sep 28, 2015 06:16 AM
old87yota
Sep 9, 2015 12:39 PM
