CV axle wobble
Old Oct 25, 2016 | 05:31 PM
ThatOneMurse's Avatar
CV axle wobble
Replaced my passenger side CV axle last night along with brake rotors, pads, and bearings. Everything went smooth until about 4 miles into driving the vehicle. Started to wobble pretty bad from 20-40 mph but would stop after 50 for the most part. Truck also pulled toward the drivers side only when the wobble was going on, which is weird because you would think if anything was causing problems in the passenger side it should pull that way? Crawled under the truck and nothing was hot, bearings sound fine, but I did notice a little bit of shaft wobble on the new side when spinning the tire. Any expertise is greatly appreciated
