coolant issue
coolant issue
ok really need a direction to go, got a 91 4runner with 3.0L. keep getting coolant to spurt out of the radiator cap, doesnt happen all the time, truck doesnt overheat just does it at random times. I have replaced the head gaskets, radiator, thermastat and 3 caps. Did a block test and it passed, compression test was pretty even on all cylinders (150 psi). Only part that has not been changed is the water pump is it possible that this could cause this issue?
Do you have an over flow tank hooked up to the radiator ?, if so is it hooked up properly ?.
I had an 85 toyota truck that would over flow every time I turned it off. It turned out that the previous owner hooked up the over flow tank backwards, so once I figured that out and hooked it up right it stopped
the1998sr5
15
Jul 14, 2020 08:35 PM
WellsR
12
Jul 31, 2015 03:27 PM
Poncho0206
Jul 10, 2015 06:21 PM
