coil spring isolators
Old Oct 7, 2017 | 02:20 PM
4sk's Avatar
4sk
i am trying to find the rubber isolaters for the rear coil springs on my 93 4run can find them for a lift but
cannot seem to find standard ones anyone replaced them would like aftermarket part number
Old Oct 7, 2017 | 04:44 PM
ksti's Avatar
I ran into this before, hard to find direct fit aftermarket.
Your probably going to have to go with universal fit unless someone here has a aftermarket part # as you mentioned.
add to compare
Energy Susp 9.6108G Coil Spring Insulator - Black, Polyurethane, Universal
$16.00 $24.24 You Save $8.24 (34%)Add to Cart
Availability: In Stock, 1-2 Business Days
  • Earn 16 points!
    Only from APW Rewards
Part Number: E1296108G Manufacturer Number: 9.6108GNote: 3.75 in. I.D., 4.25 in. Lip O.D., 5.81 in. O.D., 0.31 in. Pad Thickness, 0.56 in.Lip Height, 0.88 in. Total Height
ENERGY SUSPENSION – UNIVERSAL POLYURETHANE COIL SPRING INSULATORS
Worn out coil spring insulators contribute to less than stellar performance. These problems are easily remedied with new universal polyurethane c...VIEW MORE
Customer Rating :
add to compare
$8.87 $13.44 You Save $4.57 (34%)Add to Cart
  • Earn 9 points!
Energy Susp 9.6103G Coil Sprin
