Clutch hydraulics rubber hose
Hi all,
This morning my clutch pedal went to the floor and wouldn't return. Found my clutch master cylinder empty and traced the leak to the rubber hose on the passenger side which connects the metal hose from the master cylinder and the metal hose leading to the slave.
Any idea what this part is called, and maybe a good website for yota parts? It's. 92 truck by the way.
Thanks!
Thanks!
I used this Dorman part, works great for only $13 shipped:
Thanks for the replies guys... I did some googling right after posting, and found the part easy. I didn't think I'd be able to find it simply by searching "clutch hydraulic hose". Figured it had some more complicated name.
RustBucket... That's the one I bought, the Dorman one. Only for $15 more!
By the way, I assume the Clutch bleader will be easy to find? Somewhere near the slave cylinder?
yup, you'll see it when you're changing the hose. I suggest making sure it isn't seized before you install the hose. If it breaks off it will be easier to remove on a bench rather than on the truck.
the1998sr5
15
Jul 14, 2020 08:35 PM
the1998sr5
27
Nov 17, 2015 09:30 AM
Iceman4193
Aug 28, 2015 08:43 PM
the1998sr5
Jul 16, 2015 06:20 AM
Yes
