Checking for codes
Old Jun 9, 2007 | 03:49 PM
Robrt32's Avatar
Checking for codes
After this seafoam i'm doing i'm gonna change spark plugs and i wanna check for codes.. I have never done this on any car or truck.. I understand how to use the paper clip but which ones do i stick it in? I'm not the brightest person when comes to anything electrical , can someone break the procedure down into redneck terms for me?
Old Jun 9, 2007 | 04:25 PM
MudHippy's Avatar
I couldn't explain it any better than the FSM. Basically, your going to short 2 connectors(TE & E) with a wire(paperclip,etc.) and observe a series of flashes of the "check engine" light. Then refer to the list of trouble codes to find which code that number is. You'll figure it out.
Example: flash flash(pause)flash=21, flash(pause)flash flash flash flash=14
You can have many codes consecutively, so it might be confusing at first to seperate one from another, but the series will loop continously untill either unshorting the connectors or clearing the system memory of stored codes(described in the FSM).
93 FSM 22RE MFI System-Diagnostics page http://personal.utulsa.edu/~nathan-b...26diagnosi.pdf
Old Jun 9, 2007 | 04:51 PM
Sonofmayhem's Avatar
There should be a diagnostic box on your engine fuse box. You open the little box and if you are on the pass. fender you plug the middle and top left corner with the clip ON the first set of six connectors.
Old Jun 9, 2007 | 05:17 PM
Robrt32's Avatar
So i short it out, sit down in the truck and trun the key on and count flashes....seems easy enough.. I will give it a try in the morning, skeeters will eat you alive out there now
Old Jun 9, 2007 | 07:30 PM
DrAnonymous's Avatar
mudhippy - Do you have the entire FSM in pdf format? I have a 95 4Runner and would love to get all the chapters if possible.
Thanks,
DrA>
Old Jun 9, 2007 | 07:59 PM
MudHippy's Avatar
You betcha. Copy these.
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
The other freebies.
http://www.ncttora.com/fsm/index.html Right click, then "save target as" to download these.
smthwsn357
May 1, 2024 07:28 AM
raptor510
Feb 17, 2017 07:11 AM
nonstop
Jul 24, 2015 06:29 PM
Roger Borba II
Jul 9, 2015 05:05 PM
