center carrier bearing
Old Oct 29, 2018 | 08:40 AM
Bigmac1942's Avatar
91 ext cab 4x4 replaced u joints and carrier bearing. Marked all pieces before removing and put back together but there is a severe wobble or movement in the carrier bearing area. What could I have done wrong
Old Oct 29, 2018 | 11:37 AM
cabledawgrunner's Avatar
Did you torque the carrier nut to specs? Mine is 87 ft lbs I believe. if this nut is loose you will have an insane wobble.
justdifferentials
Just Differentials
May 21, 2017 09:17 PM
Corey
May 19, 2017 10:32 AM
Gravel Maker
Vendor Advertising
Apr 4, 2017 06:01 AM
