Can anyone give me details on turbo charging a 3vze? I need help with fuel and timing
Old Jun 19, 2017 | 04:27 PM
Blake Perritt's Avatar
Old Jun 20, 2017 | 04:56 AM
ewong's Avatar
Start at the local library
-- Ben Watson - How to tune and modify Bosch Fuel Injection (the Toyota uses a form of L-Jetronic)
-- Charles Probst - Bosch Fuel Injection and Engine Management
-- Corky Bell - Maximum Boost
The 3VZE is a "V" engine - dual exhaust manifolds.
Have you figured out single / dual turbo setup yet?
Lucas Disc injectors should be available to flow enough fuel
What are your overall goals?
Because if the HP goals are much larger than stock - then aftermarket Fuel Injection is an easier route in the longer tuning run...
