Broken Egr Valve Tube - Need
Old Apr 20, 2006 | 09:49 PM
elmo908's Avatar
Broken Egr Valve Tube - Need Some Help
I broke the metal tubing on my egr valve right at the flange :pat: . There is a small amount of over hang but the two pieces line up. I was considering JB welding it it seal it or maybe just wrapping it with rubber hose. I don't know what to do. I have succesfully swapped an engine for the first time in my life and have learned a lot about my truck. This is the first EFI car I have really ever done a large project on. It is an 86 EFI assembly on a 90 22RE block. Anything would be helpful, thanks.
Old Apr 20, 2006 | 10:18 PM
Snorkeldepth's Avatar
Welcome to the club. The JB weld should do it but it might be a bit runny. I used hi-temp two part epoxy putty I found at Kragen. It worked just fine until I got my new EGR valve and bought a new pipe to go with it. As long as you're not replacing parts the epoxy putty should do fine. It comes in a clear tube and has a grey outer part with a black core. You break off a chunk and mix it together so it's a uniform color and put it to work!
Old Apr 21, 2006 | 01:22 AM
elmo908's Avatar
Awesome thanks mans.
Blamalam
Mar 12, 2022 07:34 AM
montanatruck
Jul 25, 2015 03:45 AM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
voiddweller
Jul 15, 2015 03:56 PM
