Brake pedal creep
Old May 7, 2008 | 09:14 PM
ehrlm1's Avatar
Brake pedal creep
91 4x4 rear ABS sr5
Brakes engage but slowly creeps to the floor.
Replaced master cylinder
Bleed the lines
The brakes still are not solid. I am getting air in somewhere? Not losing any fluid though. Maybe something to do with the proportioning valve or ABS sticking open. Any ideas where to look or what to do would be much appreciated.
Old May 8, 2008 | 11:18 PM
the_supernerd's Avatar
Check the calipers and wheel cylinders. They can be bad without actually leaking on the ground. Pull back the dust boots a little and if there is brake fluid in there then they are bad and need to be rebuilt or changed.
fountain
Dec 31, 2015 06:08 AM
ty1er
Aug 1, 2015 11:53 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
PopsDad1
Jul 30, 2015 02:21 PM
