Brake line diagram
Old May 6, 2012 | 05:46 PM
gdavis67's Avatar
Brake line diagram
Does anyone have a drawing or diagram as to how the brake lines in a 92 4WD regular cab pickup are supposed to be run? I checked the FSM from 93 and it doesn't show a diagram. I am swapping the cab and box of my 92 p/u to a new frame (and SAS at the same time) and need to verify the rear brake lines. The previous owner had someone run new brake lines to the rear and I dont believe they are run correctly. They connections at the front passenger wheel well are correct, but from there back they don't seem to run as any good automotive engineer would have placed them. I would assume that they should run along the frame rail of the passenger side, but mine are just kind of loosely run above the fuel tank without any real support from the front to back. Actually, they seem to be ok under the cab, it's just from there back that they seem to be a little "iffy". Thanks.
Old May 6, 2012 | 05:52 PM
rworegon's Avatar
Does this help? You have have to use the Change Vehicle option on the second link if I did not guess right.
http://www.utoyot8.com/Picture.aspx?...ccode=&ppName=
http://www.toyotapartseast.com/Page_...VAID=2015,2021
Old May 6, 2012 | 06:04 PM
gdavis67's Avatar
Thanks a ton!! That is exactly what I was looking for. Thanks for the quick reply.
Old May 6, 2012 | 06:05 PM
rworegon's Avatar
Welcome......that site is awesome. Use it!
Sep 4, 2015 09:27 AM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
