Brake Booster Electrical
Brake booster was bad on my 92 pickup so I swapped over one from a 93 4runner. Only issue is the electrical on the pickup one went to the cap and the 4runner has a connection on the side. They are different connectors of course. Can I just cut and splice and everything will be fine? Also truck wont start now and I am assuming it is because this is not plugged in? Also what do these connection wires do?
Thanks for the help everyone.
The only time you really need that is if you never open your hood and have your oil changed by others.
It is possible while changing this you might have knocked the coil wire off.
Just put the cap on the new set up it should fit then your good to go.
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
Sep 9, 2015 06:24 AM
v_man
Jul 23, 2015 04:01 PM
