Ball Joint
Old Jan 11, 2009 | 08:50 PM
90inworks's Avatar
Ball Joint
Im sure there is a thread some where about this but i dont feel like serching no time. so if i do a 1.5 ball joint spacer is it going to be to much for the a arms? like wear my tires out on the inside as if it would with the torion bars turned up that much? my torsion bars are seized up. my a arms are almost backwards they are so relaxed.
Old Jan 11, 2009 | 09:10 PM
Matt16's Avatar
I don't understand the question, but I'm sure I could answer it if I did as I just installed BJ spacers, messed around with T-bars and alignment/
Old Jan 11, 2009 | 09:15 PM
874runnersr5's Avatar
You would have to get a alingment done after your bj.
Old Jan 11, 2009 | 09:24 PM
90inworks's Avatar
well some times if you turn your torsion bars up to much it will wear out your insdes of your tires.so if i put the bj spacer in will it wear out my tires as if i cranked my torsion bars up?
Old Jan 11, 2009 | 09:37 PM
Not if you get an alignment after you install them
Old Jan 11, 2009 | 09:58 PM
Matt16's Avatar
You need an alignment after BJ spacers, or the outside of your tires will wear fast. here's how the truck sits after the spacers (I already lowered the T bars). So, yes, you need an alignment.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
4x4YOTA
Aug 23, 2016 09:08 AM
crash813
Sep 27, 2015 07:15 AM
Odin
Sep 26, 2015 06:56 PM
