Bad Idle, TPS Questions???
Old Jun 27, 2007 | 04:02 AM
MIKEMOKAS's Avatar
whenever i first start up my truck it idles fine , but whenever it warms up it wont idle worth crap.. you can be driving push in the clutch put it in neutral and the rpm bounces between 0 and 200.. the idle adjustment is almost all of the way out and when i do adjust it, it dosent seem to do anything..
i took the throttle body off and cleaned it out and when i took the tps off i noticed that the tps had slots, like it could be adjusted.. <<could my tps be out of adjustment? or do i need a new tps??
any help on this subject is greatly appreciated!
Old Jun 27, 2007 | 12:40 PM
Yotapup's Avatar
You definitely have to adjust the TPS now after taking it off. Also turn that idle screw down. This link will help:http://personal.utulsa.edu/~nathan-b...fsm/index.html
smthwsn357
May 1, 2024 07:28 AM
Charecter1
Nov 6, 2023 10:08 AM
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
thefishguy77
Jul 30, 2015 10:59 AM
