Back Window help
Back Window help
I searched and foud a lot of information about relay problems but that is not the problem my window does move up and down a little but usually I need to help it. I heard a little about using motors from different doors but I did not get a for sure answer. SO basically I am asking will the window motor from my old drivers work on my back door. Or could there be somthing else that weras out other than my relay.
if you need to help the window up, then its more than likely in need of a motor. try contacting wabfab, he might have one ready to ship or check local used car yards for toyotas. strapp22 on here, might be able to assist with cross referencing other motor options.
lee
lee
Take off the trim on the inside of the door and lubricate all the runners and sliders and moving parts. You will be amazed at the difference it makes. When I got mine the glass was doing the same. I replaced the relays with not much success, then lubed everything and now it works like new.
Jun 1, 2021 01:51 PM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
Jul 6, 2015 04:07 AM
