AC Wire
Old Jun 12, 2012 | 12:46 PM
Tolbert's Avatar
AC Wire
I have a 92 Toyota SR5 V6 with the 3.0. I recently put on a new ac compressor but the wire that the compressor hook to is gone. Does anyone know which of the wire looms it goes to?
Old Jun 12, 2012 | 12:56 PM
Discombobulated's Avatar
Was this a direct replacement or conversion?? If it came with ac I don't see why it wouldn't be there unless it had been cut off or stashed behind something for years. If you are doing a conversion on my 22r I got the wiring from the yard that went from the compressor to the harness plug but the 3.0 could be totally different.
Old Jun 12, 2012 | 08:47 PM
Tolbert's Avatar
This was a direct replacement. The original compressors clutch was gone when I got the truck and the wire was nowhere to be found.
Old Jun 12, 2012 | 09:06 PM
Hmmmm, so when you got the truck I take it the clutch was metal to metal while running and you decided to replace but the truck had no ac when you tried it? If it was original you should have something stashed somewhere? Or the PO pulled it off the harness, cut it? It has to have something left. Worst case if you have a junkyard close to you go check out any 3.0 and you should find the missing link. People do weird things when stuff doesn't work I would imagine they did just that something weird. Good luck and post progress
Old Jun 13, 2012 | 11:52 AM
Tolbert's Avatar
Thats what they did. The clutch was gone as well as 2 bolts and the tensioner pully. I got that all replaced just need to get that wire and charge the system.
Old Jun 13, 2012 | 12:04 PM
93toyrunner2's Avatar
http://www.ncttora.com/FSM/1990-1995...ci/aircond.pdf
80Truck
Oct 12, 2025 07:25 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
ToyoToler
Aug 8, 2015 08:43 AM
Daneums
Jul 28, 2015 11:57 AM
TDonkey
Jul 26, 2015 10:14 AM
