95 toyota pickup
Old Aug 30, 2017 | 05:38 PM
Gunner2012's Avatar
95 toyota pickup
I have a 95 pickup with a 4.5in suspension lift.i am runnin 33×12.5 tires.when I turn the wheel all the way left or right the tires rub my fenders.i am wondering if a 2 in body lift would help and if I would have to modify anything else with the body lift like steering box or shifter?any advice would be appreciated.thanks
Old Aug 31, 2017 | 06:58 AM
akwheeler's Avatar
I think you should check your wheel back spacing, I'm pretty sure 33s shouldn't rub with 4 1/2 inches of lift. Is your truck IFS or did you go with a SAS? I have a 4 inch trailgear SAS setup running 37s and no rub (you get more lift than 4 inches with this kit though).
Old Aug 31, 2017 | 12:06 PM
Gunner2012's Avatar
it's IFS not sure what the back spacing is I'll have to check it.i didn't think it would rub with the lift either but it does
Old Aug 31, 2017 | 12:29 PM
Gunner2012's Avatar
the wheels are 15×10 with 3.625 back spacing
Old Aug 31, 2017 | 01:54 PM
akwheeler's Avatar
I'm not familiar with what your backspacing should be, it just seems like that might be the issue since you can get a 31 on a stock truck with no lift. Are you running spacers?
Old Aug 31, 2017 | 02:08 PM
Gunner2012's Avatar
no spacers
