95 steerling column in an 88? or steering wheel?
Just curious if the steering column and or wheel from a 95 will fit my 88... I found an entire column with a wheel that is much nicer than the stock no tilt in my 88... Any ideas or other steering wheel upgrades from other Toyota's that will fit?
I found this chart on a steering wheel adapter spec sheet, would this mean that the stock wheels from these vehicles "should" be able to be made to fit??
· Toyota MR2 84—95
· Toyota Corolla 84—87 / 89-97
· Toyota Corolla GT-S 88—91
· Toyota Land Cruiser 91—96
· Toyota Pick Up 87—96
· Toyota 4 Runner 90—96
· Toyota Tercel 90—98
· Toyota Paseo 92—97
· Toyota Camry 87—90
· Toyota Celica 2WD 86—93
· Toyota MR2 84—95
All the toyota steering columns from 86-95 have the same size shaft. However, you cannot move over the entire column without some modification. You can use the steering wheel, and you can also use the LC steering wheel.
terminator
Jul 27, 2015 07:13 PM
