95 4runner 3rz FSM Amazing but
Old Aug 17, 2018 | 09:31 AM
Michael Floyd's Avatar
Exclamation 95 4runner 3rz FSM Amazing but
I purchased a 95 Body that had a 3rz in it manual Trans. I'm putting it on my built 85 4runner frame 22re. So all i need to do is power the 22re ECU i pulled complete harness from 85 . I think i can just line up the right wires to a part of the 95 harness like the Batt W etc and it should all run off the 95 BCU. Correct me if im wrong. So my main Question about the FSM is its amazing and full of great information. But i cant find just a picture of the 95 ECU pin outs so i can just connect the right wires to my 22re pin outs. Can anyone point me or link me the right image i can only find 22re and Tacoma 3rz and read they are different with 4runner. Thanks in advance
Old Aug 17, 2018 | 12:22 PM
wyoming9's Avatar
Red face
You have the hard copy of the EWD for both years??
Your using the Engine harness and ecu with the 22re from the 1985
The cab harness is from a 95 3rz 5 speed
You have to sit down using both copies and merge the cab harness into the ECU a little more then just power the ECU
Just like any other engine swap even though yours is a cab swap
Old Aug 17, 2018 | 12:27 PM
Yeah I know there's more than just the power wire but they shouldn't be but about 8 to 10 wires if I'm correct right. So I really just need the pinout for the 95 ECU so that I'll know what to make to connect to my 85 ECU harness. If I'm thinking correctly
Old Aug 17, 2018 | 12:30 PM
And yes I do I do have the wiring diagram from the FSM but I just want to be able to look at the PIN plug and in something just tell me what 1 2 3 4 5 is
Old Aug 17, 2018 | 12:34 PM
Just like this for a 4runner 3rz
some drunk guy
Jan 10, 2014 09:41 AM
KLM
Mar 22, 2011 12:46 PM
Scofco
Oct 11, 2006 07:56 AM
SloPoke
7
Mar 11, 2005 05:48 PM
