94 pickup 2.4L tow question
Old Jul 2, 2018 | 08:42 AM
Mason Edmison's Avatar
Hi,
Acquired a 94 pickup recently with a rusty frame that has been patched at two spots - :1 by the drivers front (where the steering gear mounts to the frame) 2: passenger side below the seam between the bed and cab).
Otherwise the frame is pretty rusty but I do not see any rust holes. I have done a fair amount of poking with a knife and screwdriver and it seems solid - I am going to take a closer look at the passenger rear as I hear this is a common rot spot.
My questions are:
1) Would you all pull a small-ish trailer a few short ish trips (10-15 miles)? Total weight would be well under 1K probably more like 5-600 pounds.
2) In terms of dealing with this rust - does it pay to coat the underside with fluid film or am I better off grinding and sanding the rust away and applying some rust bullet? I do live in WI so it is quite salty here come winter time.
Any other places on the frame I should pay especially close attention too?
Thanks!
Old Jul 2, 2018 | 07:24 PM
dropzone's Avatar
Fossilized
Pics of the rust would help
Old Jul 2, 2018 | 11:20 PM
wyoming9's Avatar
Red face
Maybe you can merge his 2 threads ??
LawnGnomeHitman
Sep 16, 2009 01:05 AM
MorganicFunk
Jan 2, 2009 03:14 PM
coopma
26
Oct 5, 2007 04:05 AM
jsnby
Dec 4, 2006 08:47 AM
Denk
Oct 1, 2003 10:44 AM
