94' 4Runner oil pan removal?
Subscribe
Jul 27, 2009 | 07:43 PM
Got a leaky oil pan. Pulled the bolts, braces and flywheel cover. Now Im stuck! Do I have to remove all the linkages to the tie rods, idler? With out fubar'n the rubber boots can you guys explain the method to this madness.
Reply 0
Jul 27, 2009 | 08:20 PM
Easiest if you drop the front differential...if its not 2wd..
Reply 0
Jul 27, 2009 | 09:50 PM
I pulled the diff to do the pinion seal and cv shafts. Now the pans hanging and hitting all that suspension crap.
Reply 0
